Vertex Displacement Mapping using GLSL
Initial draft: March 26, 2006
Update: November 5, 2006
Update: November 22, 2006
2 - Principle of Displacement
The basic element for the deformation is the vector queried from the displacement map. This vector usually holds either a RGBA-color or a scalar color (gray level height map). We will use this vector and more precisely the sum of its components as a factor to change the vertex position. One of the common methods is to move the vertex position along its normal proportionately to the previous factor.
Fig. 3 - Displacement principle
The schema of the figure 3 can be summed up by the following relation:
P1 = P0 + (N * df * uf)
where P0 is the original position of the vertex, P1 the vertex position after displacement, N the vertex normal vector, df the normalized displacement factor (i.e [0.0; 1.0]) and uf an user scaling factor. df can be get with the following relation which converts a RGB value to a grey value:
df = 0.30*dv.x + 0.59*dv.y + 0.11*dv.z
where dv is the vector fetched from the displacement map for the current processed vertex.
Now that the theory is okay, let's go to the practice...
Page generated in 0.001755952835083 seconds.
