NVIDIA nZone.com NVIDIA Developer Blog
NVIDIA G80: OpenGL Programming
By: Christophe [Groove] Riccio - www.g-truc.net
Initial Version: November 12, 2006
Edited and Translated by the oZone3D Team
Last Update: March 25, 2007
Introduction | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9
2 - Milestone
Some new graphic controller generations bring new stages in graphic programming, and we are facing such a stage which, with OpenGL, goes further than the very media geometry shader. If we just go back to the NVIDIA GPU's history, the GeForce 256 and GeForce 2 allowed vertex acceleration and, later on, their programming. Regarding the GeForce 3 and 4, they have contributed a lot to texture combining, but have also diversified texture formats (cube map, shadows, 3d texture, etc.). For the GeForce 5, it brought a real programming of the fragments processing, while the GeForce 6/7 stamped their time with the development of the float internal format of all type of textures, 2D texture, frame buffer, non power of two textures, which caused some hysteria about the High Dynamic Range (HDR).
Now, the GeForce 8800 philosophy seems pointing towards data handling and their storage. Bindable uniform, texture array, texture integer, texture buffer, transform feedback are among many notions that are focusing on this target which will bring us to the GPGPUs programming (General Purpose Graphic Processing Unit).
The GeForce 8800 features about 21 new OpenGL extensions, which makes a total of 150 OpenGL extensions [1] on this board. Here is the list:
  • EXT_bindable_uniform
  • EXT_draw_buffers2
  • EXT_draw_instanced
  • EXT_framebuffer_sRGB
  • EXT_geometry_shader4
  • EXT_gpu_shader4
  • EXT_packed_float
  • EXT_texture_array
  • EXT_texture_buffer_object
  • EXT_texture_compression_latc
  • EXT_texture_compression_rgtc
  • EXT_texture_integer
  • EXT_texture_shared_exponent
  • NV_depth_buffer_float
  • NV_fragment_program4
  • NV_framebuffer_multisample_coverage
  • NV_geometry_program4
  • NV_gpu_program4
  • NV_parameter_buffer_object
  • NV_transform_feedback
  • NV_vertex_program4
Wouah! Unlike one could think, all those extensions are exclusively proprietary and have been developed by nVidia. There are two exceptions with some S3 contribution for EXT_texture_compression_latc and EXT_texture_compression_rgtc.
Editor's Notes
  • [1]: You can use the GPU Caps Viewer utility to see all OpenGL extensions supported by your graphics card: GPU Caps Viewer Homepage.
Page generated in 0.0019340515136719 seconds.
