Here is a small piece of code that can be useful if you need to quickly generate traces (or log) in your apps:
class cLog
public:
cLog(char *logfile){};
static void trace(const char *s)
{ if(s) log << s << std::endl; };
static std::ofstream log;
std::ofstream cLog::log("c:\\app_log.txt");
Just use it as follows:
cLog::trace("this is a log");
cLog::trace("this is a second trace");
we should put std::ofstream cLog::log(“xxx”) to cpp file, not the header file.
