It’s nice to come back to code!
I’m currently working on a new and simple framework for my OpenGL experimentations before implementing the algorithms in the oZone3D Engine . RaptorGL is a little bit too heavy for simple tests so for the moment I drop it. This new framework I called XPGL (eXPerimental Graphics Library), allows me to quickly test the new algos I’m working on. Every time I have to code a little but fully operational 3D demo in c++/opengl, I spend lot of time for a small result. In these moments, I say to myself that Hyperion is a very cool tool.
Okay, let’s see a weird behavour of radeon gpu. At the moment, my graphics controller is a Radeon X700. With the latest catalyst drivers (6.6), this graphics board should be an OpenGL 2.0 compliant CG. A little check to the GL_VERSION tells me the X700 is GL2 compliant. Then the X700 should handle non power of two texture since this feature is part of the OpenGL 2.0 core. But the GL_ARB_texture_non_power_of_two string is not found in the GL_EXTENSIONS. Maybe ATI does not mention the extensions that are part of the core. Anyways, I loaded a 600×445 npot-texture on a mesh plane and the X700 seems to support this texture. But with a ridiculous fps of 1… Software codepath? I think so! So I decided to load the same texture with power of two dims (512×512) and the fps is become decent again. With my gf6600gt (with the forceware 91.31) I never noticed this effect/bug because the GL2-support is better and nVidia gpus correctly support non power of two texture. You can download the demo with the npot and pot texture (the one mapped onto the mesh plane) hereafter and do the test for yourself. Feel free to drop me a feedback if you wish.
But keep in mind that graphics hardware is optimized for POT textures. Try to use POT textures in order to maximize your chances to see your demo running everywhere.
